Warning: You are now accessing Matomo from
https://qlf-piwik.inria.fr/, but Matomo has been configured to run at this address:
https://qlf-matomo.inria.fr/.
Click here to access Matomo safely and remove this warning. You may also want to contact your Matomo administrator and notify them about this issue (
click here to email).
How do I fix this problem and how do I login again?
The Matomo Super User can manually edit the file /path/to/matomo/config/config.ini.php
and add the following lines:
[General]
trusted_hosts[] = "qlf-piwik.inria.fr"
After making the change, you will be able to login again.
You may also disable this security feature (not recommended). To do so edit config/config.ini.php and add:
[General]
enable_trusted_host_check=0
